Author Topic: Split Lath
Isla
Newbie
Post Split Lath
on: May 18, 2013, 08:39
Sweet chestnut coppice stock can be used to produce split lath either for use to secure roof tiles & thatch with thinner splits going for use as ceiling lath.
Herbert Russell starting a split in a sweet chestnut lath.
Once the split is started the lath stock is moved to the "break" where the split is advanced and controlled using a froe.
Isla
Post Re: Split Lath
on: June 2, 2021, 13:43
10 years later the lath making process was demonstrated by Herbert Russell at The Weald & Downland Museum. The lath making process involves clamping a short length (4ft) of a sweet chestnut round log in the clamping brake in order to remove the bark.
The log is then upended and halved progressively to produce cake slice stock.
The inside heartwood strip is removed following which the resultant thick strip is then cleved and split using a froe in the brake.
The strips produced are then flatened on the shave horse using a draw knife.
Post Re: Split Lath
on: June 2, 2021, 13:52
The apocalyptic scene below is of the woodland where the sweet chestnut grew last year.
Already the following spring new shoots are sprouting from the cut coppice stool.
An adjacent previous years sweet chestnut coup is already regenerating at an alarming speed.
Version: 1.0.34 ; Page loaded in: 0.035 seconds.
