Author Topic: Black Poplar
Post Black Poplar
on: May 16, 2012, 08:04
Hi,
I am examining the use of Black Poplar timber in the construction of old timber framed houses and have been given a section of recently cut timber taken from a tree in Blewbury where an extremely large branch (think trunk) was amputated for safety reasons. Several of these trees are growing in Blewbury alongside the spring line chalk streams with most of them appearing to be quite healthy.
The rate of growth in this type of tree appears to be quite fast and though the tree books say that it has a creamy white indistinct wood I have found that the opposite ie true i.e. it has a very pronounced lime green heartwood with a creamy white sap wood. It is a difuse porous hardwood.
Black poplar is known to have been used to make curved cruck blades for timber framed buildings but since very few of these trees survive today I very much doubt whether there is any significant recent evidence based knowledge about the use of black poplar timber other than in a landscape and wildlife conservation use.
What knowledge of any kind is out there regarding black poplar ?
Where are these trees to be found in South Oxfordshire & The Vale ?
Does anyone know of timber framed buildings made from or containing black poplar ?
Post Re: Black Poplar
on: July 6, 2014, 07:31
Black Poplar is possibly more widespread in Oxfordshire than currently perceived.
Wetlands and stream side locations are favoured by black poplar and so these can be seen along the spring line between the Berkshire Downs and Vale of White Horse chalk streams in villages like Blewbury, Shillingford, etc. It is more than likely that some of the buildings in these areas will contain black poplar.
These are large imposing trees with a very distinctive winter silouette.
The bark is thick, rough with deep fissures.
In summer the trees are clothed with light green heart shaped leaves.
The timber is unusual in that the heartwood is olive green with a contrasting creamy white heartwood. In mature tree trunks the heartwood is dominant with only 2-3 years worth of sapwood present unlike the younger branchwood shown and taken from the same tree.
The timber when felled is very wet and heavy. As it dries the bark separates from the timber and when removed reveals distinctive upstanding spiral flutes and small pimples which are easy to detect either visually or by running a hand over the outside surface of the tree trunk.
Version: 1.0.34 ; Page loaded in: 0.014 seconds.
