Pages: [1] 2
Author Topic: Tree Felling - Douglas Fir - Western Red Cedar - European Larch
Post Tree Felling - Douglas Fir - Western Red Cedar - European Larch
on: February 5, 2026, 09:52
A 117ft [35.5m] Douglas Fir [pd 1959] was felled in preparation for making a new timber drying / bodgers shed.
The butt revealed squirrel bark stripping damage done early in the life of this 67 year old tree with the full extent of this currently unknown.
The tree got hung up between twin upper stems of a western red cedar and it took a lot of effort to eventually manage free this tree when one of the WRC stems broke allowing the DF tree to fall.
A good straight clean DF log was obtained with minimal branches on the lower 60 ft length.
In due course the WRC will be felled to create shingle stock from the lower single stem.
The log will be bucked to length, extracted and converted on our sawmill. This will require an enforced wait period to allow the ground to dry out and firm up following a very wet January.
Post Re: Douglas Fir Tree felling
on: February 11, 2026, 13:36
Seems that the Gruffallo was watching our efforts to take down big Dougie !
https://t.co/M5gU8DK9En
A large 16' log was inserted under the base of the hung up log butt and pivoted over the stump to form a fulcrum for the 16' log to be used as a lever to lift and wiggle the stem which in combination with sideways pull from the come-a-long eventually caused the log to crash to the ground tearing off one of the Western Red Cedar twin stems.
on: February 15, 2026, 12:18
The felled big Douglas Fir was snedded (branches removed)
and then the damaged Western Red Cedar tree was felled.
Some typical WRC butt rot was observed
and the broken twin stem crotch that had held up the big Douglas Fir was more clearly witnessed.
on: February 17, 2026, 19:32
A nice straight 80ft European larch tree was felled.
The butt log will be used to make components for the alternating stair.
We now need to fell another European larch tree of similar quality and larger dimensions to make the parts for the ground floor sill frame needed for the new Bodgers / Timber Drying shed.
Post Re: Douglas Fir - Western Red Cedar - European Larch Tree felling
on: April 4, 2026, 09:22
We felled a neighbouring larch tree and were taken aback that this measured up at 140ft tall once on the ground !
Needless to say it got hung up on an oak tree and required 2 winches to pull it down.
A recently planted oak shelter got slightly bent but not damaged.
on: April 12, 2026, 08:56
The 141ft European Larch tree was bucked to length and extracted to the cruck barn employing 3GP (3 girl muscle power), hand winches, round fence post rollers & levers plus good team working.
The logs will be converted to form 2 long sills (17' x 8" x 8") + 3 cross sills (12' x 8" x 8") for
the new bodgers / timber drying shed.
Log#1 will likely be able to produce good knot free boards from the outer part of the log that can be used to make the treads for the alternating stair to be installed in the cruck barn.
The 17ft butt log from the 80ft European Larch tree felled will be used to make the alternating stair stringers and hand rails.
Post Re: Tree Felling - Douglas Fir - Western Red Cedar - European Larch
on: April 24, 2026, 19:43
After 2 days of sawmill maintainence we put Cat through her paces to square up a knotty European Larch log (no 6 above) taken from 82 - 90 ft up the tree.
This produced a good 8ft long timber wall stud ready to have any waney edge bark removed using a draw knife.
The technique or practice of leaving a small amount of bark on the corners (aris) of the beam is known as "squeezing the log".
on: July 16, 2026, 09:09
A volunteer team from AWE pulled out the remaining European larch butt log to the log pile. They then peeled all of the remaining logs noting that it only took 12 mins to peel the butt log.
These logs are now ready for conversion to make long & cross sills, wall studs and wall plate packer (see bodger shed drg)
on: August 15, 2026, 10:43
The 2 x 17' long E. Larch logs have now been converted on the sawmill to create 2 off 8" x 8" x17' long sill beams together with 1" thick planks falling.
We are nearly ready to start framing.
on: August 21, 2026, 09:21
The 141 ft E. Larch tree has now been sawn and stacked to produce the 8" x 8" sized stock needed to make Phase I sills for the new bodgers shed together with planks falling that can be used as roof sarking.
Pages: [1] 2
Version: 1.0.34 ; Page loaded in: 0.057 seconds.
