Author Topic: Tree House
Post Tree House
on: December 18, 2013, 13:35
A very useful way to build a secure cabin in the woods is to consider employing a structure that is elevated above the woodland floor in the trees i.e. a treehouse.
No foundations are required and if the treehouse deck is secured to larch trees (as per the photo above & below) then wood rot should not be a problem. The ladder can be easily removed to ensure excellent security.
Depending on the spacing of the trees it might prove necessary to build the cabin around a tree and the roof can be sealed using a flexible membrance (rubber inner tube). Excellent blending of the tree house with the woodland is obtained naturally courtesy of the surrounding underwood
Post Re: Tree House
on: November 10, 2021, 09:26
This tree house makes good use of 3 large Japanese larch trees that have provided a solid base upon and aroumd which a platform and shed have been mounted reached by a stairway wrapping around one of the trees.
Will the fixings damage the trees or restrict growth ?
Do the occupants get sea sick due to any sway of the trees ?
Version: 1.0.34 ; Page loaded in: 0.031 seconds.
