Author Topic: Sawpits
Post Sawpits
on: June 12, 2013, 12:41
Many woodlands contain archaeological remains of former traditional woodland working methods such as sawpits. These pits were, whenever possible, located on sloping ground near to a woodland track.
The process employed is often referred to as pit sawing however in the case of Chiltern Hills sawpits this could possibly be misleading as most woodland pits are rarely more than 3-4 feet deep and hence could not accomodate an underdog as in a 17th century (brick lined) pit.
The photograph below is of Robert Spinner of Kent (Maskill, 2011) obtained by her from the various photographic collections stored at The Museum of English Rural Life, Reading, Berkshire, England.
It is more likely that hewn logs were simply upended into the shallow woodland pit by standing on one end of the log causing it to rotate and pivot on the upper bank then inserting a short legged trestle stool under the log to provide tempory support whilst a triangular saw brake was fitted.
The bottom of the log needs to be weighed down to prevent it from moving forward whilst the sawyer stands on top of the log. The historical evidence for the use of this approach to rip saw logs is illustrated in a Chinese postcard of sawing in Tsingtau circa 1900 where the bottom of the log is weighed down with a large rock.
This counter balance weight effect can also be achieved by employing an adjustable triangular sawing brake as demonstrated by Henry Russell at Frame 2010.
A long heavy log running across the length of the pit could then be attached to the apex of a brake using a Spanish windlas rope to raise the log just sufficiently to apply a downward force and moment on the brake apex to allow sawing to commence.
This process is called scie-sawing (as in the see-saw Margery Daw nursery rhyme). The log can only be sawn half way down its length using this process before needing to be be flipped over in the brake or turned in the pit to enable the log to be ripped down from the other end to meet the first saw cut (kerf). This gives rise to a very distictive conversion pattern that can be seen on early medieval buildings [Merchant's House, Tewksbury.]
This conversion method was also employed to convert cruck blades with the distinctive scie-sawn pattern able to be seen on the back face of an Oxfordshire Cruck blade.
The kerf angle is shallow towards the top end of the blade and steepens towards the centre indicating that the sawyer stood in a fairly fixed position adjusting the angle of cut as the saw came closer to his feet. This is clearly illustrated in a close up of Cruck Blade No 1 of the Oxfordshire Cruck shown above. This kerf pattern tends to suggest that the scie sawing process might well have been undertaken by one sawyer as the kerf advanced through the log and space underneath the log could no longer accomodate an underdog as is beginning to be illustrated in the Henry Russell photo above. A common assumption made by some historians is that rip sawing was done by men whereas women actually have a much better stomach muscle structure enabling them to undertake this process with relative ease as is ably demonstrated by Barabara Czoch on the Poland Synagogue reconstruction project.
Cruck blade No 2 illustrates the kerf overlap and hence also demonstrates the order in which the cruck blade was rip sawn (top down then bottom up) eventually resulting in the triangular snap area when the log came apart.
The other three faces of the cruck blade are hewn and a pronouced degree of grain tear out is evident most probably due to a dull hewing axe being employed. Waney edges are also evident demonstrating that a tree that was dimensionally just adequate for its chosen purpose was selected, felled and employed to good effect thereby minimising waste and limiting the required tree growing cycle (60 - 70 years).
Ref:- MASKILL, L., 2011. The Farnham Park Sawpit, Farnham. Surrey : Rural Life Centre, un-numbered report.
Post Re: Sawpits
on: July 2, 2014, 09:59
A good example of a Chilterns sawpit was seen in Pitmans Copse, South Oxfordshire.
The pattern for sawpits is now fairly clear in that excavated material is heaped on the downslope side of the pit to create a bank
During a visit to woodland at Christmas Common the remains of another sawpit were spotted in a woodland pig pen.
In the same woodland a deep pit was observed with no downslope spoil. It was suggested by some that this might have been a flint pit but few flints were in evidence in or around the pit. Elsewhere in the same woodland another method for mining flints was encountered.
Post Re: Sawpits
on: July 2, 2014, 11:52
In 2006 The Chilterns Open Air Museum held a traditional sawing event which fortunately was recorded by John Hyde-Trutch (Maskill, 2011).
A deep pit was dug and timber lined to prevent sidewall collapse. Some of the excavated spoil was heaped up on the exterior face of the timber shoring creating two banks.
Some flat timber baulks were placed on top of the spoil banks and then cross bearers added upon which the timber to be sawn was placed.
A long whip saw was employed to rip the log however the position adopted by the top dog apears to be a physically demanding stance and clearly quite an awkward one from which to steer the kerf (cut).
I don't think that this is how the traditional Chilterns sawpits illustrated above by the OWG Executive Trustee were made and used but maybe are more closely aligned to later dug and lined deep (6 ft) pits (Winter, 2005).
refs:- MASKILL, L., 2011. The Farnham Park Sawpit, Farnham. Surrey : Rural Life Centre, un-numbered report.
WINTER, SEAN. 2005. Timber-getting in the Forest: an archaeological case study of six nineteenth century sawpit sites, Dissertation (B.Sc.), Perth, University of Western Australia.
Post Re: Sawpits
on: October 11, 2015, 15:12
Ian Taylor of Lakeland Coppice Products has recently run a course at the Bill Hogarth MBE Memorial Apprenticeship Trust (BHMAT) in Cumbria where a Woodland Pioneer scheme operates to recruit and train coppice worker apprentices.
A frame was lashed together beside a bank to form a platform upon which the cant could be secured.
Rip sawing proceeded with the top dog pulling the saw up -
- and the underdog pulling the saw down !
A worms eye view of rip sawing near the end of the cant.
A sawn plank exhibits the characteristic kerf pattern obtained from a big tooth whip saw which is much wider than that made by the medieval style frame saw.
Sawing proceeded apace eventually producing a pile of rough sawn planks ready for joining together to make a bench style picnic table.
Ian Taylor and his apprentice stand proundly beside the finished table.
The finished bench stands outside the centre ready for use by all.
The Oxfordshire Woodland Group would like to thank Rebecca Oaks for the kind permission received to post her photographs above of the woodland pioneer events on the OWG web forum.
Ken Hume OWG Executive Trustee
Post Re: Sawpits
on: February 3, 2021, 14:15
A Surrey sawpit in :-
JEKYLL, G., 1904. Old West Surrey - some notes & memories. London: Longmans, Green and Co. pp194
Post Re: Sawpits
on: September 26, 2021, 07:56
The Weald & Downland Museum has a timber lined sawpit (recreation) featuring octagonal barring rollers to propel the cant forwards / backwards.
This enables the saw to progress through the kerf and helps to minimise the need to extract / insert the saw to hop over a fixed support.
Post Re: Sawpits
on: May 12, 2022, 08:31
Work to survey and record the current profile of a woodland sawpit has now commenced in Sep 2020 using laser survey equipment. The proposed location of a cross section trench was established to determine the original depth and profile of the sawpit.
Preliminary survey results (original land slope correction)
Post Re: Sawpits
on: May 12, 2022, 08:59
The pit was carefully excavated. The major discovery found was that the sawpit was lined with a thin layer of chalk. Why?
The original sawpit profile was accurately measured and recorded.
Version: 1.0.34 ; Page loaded in: 0.059 seconds.
