Author Topic: Cruck Frame No 3
Post Cruck Frame No 3
on: March 4, 2017, 08:20
Following completion of the centre cruck frame no 2 -
- cruck frame no 3 was laid out on top of cruck no 2 with the cruck feet positioned directly over the cogged housing in the long sills.
The line and level of the cruck blades was checked and tested at the apex, collar, mantle and feet locations.
Post Re: Cruck Frame No 3
on: March 10, 2017, 08:59
The cruck blades were levelled and then the smaller of the blade was raised and positioned on top of the other and levelled again with the apex invert plumbed over the framing floor centre line string and height nail.
The top blade was approx 6.5" thick (slightly variable over the joint) and so independant horizontal lines were scribed on both sides of the top cruck blade approx 3.25" down from the top surface using the laser level. The horizontal lines were then intersected by vertical plumb lines scribed down the vertcal face interfaces. The compasses were set at 6.5" and then this was stepped down from the top lap joint face to mark and position the lower cruck lap joint face.
The lap joints were then cut and smoothed to the lines and remated.
The apex lap joints were then pulled up tight using an 8" "G" clamp -
- resulting in the horizontal scribe lines now being coincident.
The cruck mantle was then pulled into place, centred and set at the required distance up from the cruck feet
Ken Hume - OWG
Version: 1.0.34 ; Page loaded in: 0.031 seconds.
